Jeremy Hegna
- Nov 28, 2000
"Again I compared two preamps (3801 and 3802) hooked up to one amp (ATI or B&K) and I couldn't tell the difference. So according to you the preamps must be the same on the 3801 and the 3802. But when you listen to the 3801 and the 3802 on their own they sound different. So the difference must be in the amp section, reinforcing my opinion."
I'm not saying that different amps don't sound different. What I am saying, IMO....a pre/pro will sound more different than different amps will....not that that makes much sense, but I'll give an example.
A B&K Ref 30 sounds different to me than a Tag with the same amplifier. The sound difference is more extreme between the pre/pros with the same amp....than the same pre/pro with different (same quality, same wattage) amps.
It's probably much more of a chore to find the difference in the 3801/02 combo, because the pre/pro section is identical or very close.
The 4802 and the 5800 are built quite a bit better with special shielding of internal components, higher S/N ratios, etc.
Jeremy
Jeremy
