Tim Shafer
- Jul 25, 2002
I designed and built my own home theater, and now I am looking for a simple solution to a common problem.
Like most of you, my audio/video equipment is located in an enclosed dedicated closet. I have considered using a relatively expensive fan to exhaust warm air from this room, but was frustrated with reliability problems and noise.
I have come up with a great solution, but need your help. I have installed an ultra-quiet NuTone bathroom ceiling fan. Virtually silent (.8 sones), powerful (80-100 CFM), and completely reliable. My only issue is controlling it. Currently I have resorted to manual wall switch.
I need a very simple line voltage (120v AC) thermostat (preferably adjustable) that will turn this cooling fan ON at a preset limit, and OFF again when the room is cooled. I want set-it and forget-it simplicity.
Any thoughts/help would be greatly appreciated.
Thanks in advance, Tim
