I am going to suggest that you Google for "Stacy Spears Shootout Secrets". These are reviews of progressive scan DVD players that I recommend anyone read before purchasing a progressive scan player.
To obtain progressive scan output, all DVD players use a built in de-interlacer. The quality varies all over the map. DVI output is not going to give a high quality picture if the de-interlacer is mediocre.
Actually I will say you can safely skip the above reviews if the player you are considering has a Silicon Image or Faroudja de-interlacing chip. These are excellent chips. Players without these brands of chips and with a choice of film mode versus live video mode probably have a lower grade de-interlacer chip.
The Zenith DVB318 was available at $100 refurbished recently. It does well at 1080i over DVI with the new firmware which should come with all refurbished units but not very well at 480p. I have had one for about a year.
The Cyberhome uses HDMI for the output. I have had one for about 2 weeks and have been very pleased with it considering the price. I have it hooked up to my DVI input on my tv using a HDMI to DVI adapter.
It is the Cyberhome CH-DVD655. I bought it at Wal-mart figuring if it didn't work out I would return it but I have been pleasantly surprised. It looks better than my DVD player/recorder (Toshiba) running through component cables.
