Frank Palazzolo
- Aug 18, 1999
Hey guys, I have the Denon avr-3300 receiver and I would like to hook up my new Panasonic RP-82 for analog input to get the true surround greatness that DVD-A now offers me. I am really not sure how to hook everything up as far as settings go through the reciever menu's or the new dvd player menu's for that matter. I was hoping that somebody out there might have a similar configuration who could help me out. I now have the component output on the rp-82 going to the component input on the TV (Sony Wega xbr-250). Which is working fine, then I have the digital coax out on the rp-82 going to input on the receiver which is also working fine. The next thing I did was hook up 6 rca cables to the outputs on the dvd player and run them to the 5.1 inputs on the receiver which I though would be correct. I believe that this may be right because I notice a sound quality difference immediately when playing a dvd-a disk. The problem is that now that these two connections are connected (digital coax, analog 5.1) The lowest volume setting on the receiver which is -60 is blaring loud for some reason. I hope that this all makes sense to somebody because my wife won't let me have movies and dvd-a disks at this volume for much longer. She is convinced that the new dvd player is broken so she is begging me to take it back now. I am laughing at her but If I can't figure this out I will either go crazy or never hear the end of it. Maybe I should try hooking the 6 analog output cables to the ext in on the back of the receiver???? HELP ME PLEASE! my marriage may depend on it. Any help is appreciated. Thanks in advance!:frowning:
