DisneyStore.com Monsters Inc. PreOrder Info (1 Viewer)
Chris Sigua
Checkout it out:Link Removed
$29.99 - DVD + 4 Lithographs + 2 Plush (Boo and Little Mikey) + Pin
$25.99 VHS + 4 Lithographs + 2 Plush (Boo and Little Mikey) + Pin
$19.99 - DVD + 4 Lithographs
$15.99 - VHS + 4 Lithographs
Not sure if this is at the B&M stores also, but I'll call today to find out.
David Lambert
I wonder if the $29.99 DVD and the $19.99 DVD are both the same thing, just with 2 toys and a pin, or if there is a standard vs. collector set going on here.
Didn't Disney plan a standard set and a collector set for this one, just like they've done with many others, such as A Bug's Life?
In either case, I'm certain that these deals are Disney Store exclusives. The lithographs always are, for sure.
Chris Sigua
Just called and they aren't doing it yet since they're doing Return to Neverland at the moment. They weren't sure yet when the stores would be doing it but it "SHOULD" be the same is what the CSR said. The only difference is if you order it at the store, you get all the extras when you place your order and no S&H of course.
Dave E H
Is this a standard edition DVD? Are they doing a special edition? I hated buying the regular Bug's life THEN the special edition...
Chad Gregory
Dave,
Relax, there is only one edition of Monsters, Inc. coming out. Check the specs on this release, what else could be included? Billy Crystal himself?
Buy without worry, though I'm sure it will be $16.99 at Best Buy in September. Personally, I believe the lithos are worth the couple bucks...
-Chad
Pat
According DVD Profiler there are 3 versions of Monsters Inc.
Monsters Inc. UPC Code 52619-98230
Monsters Inc. Special Edition UPC Code 86936-16488
Monsters Inc. Collectors Edition UPC Code 00006-00006
I'm not sure if it's correct or not, but just more info to digest.
David Lambert
Hmmm...looks like the only version which will be available will be a 2-disc version that is labeled as an SE rather than as a CE! SRP $29.99:
Link Removed
Jeff Kleist
There will only be an SE for Monsters INC
No idea why DVD profiler has the lisiting for a non-SE
johnmash
