Wayde_R
- Aug 25, 2003
Hello
I'm looking around at specs on various amps and am finding some interesting features on some JVC offerings. These new generation of digital amp/receivers by JVC and Kenwood (I've only looked at specs from both) show some weird specs I'm not used to seeing on conventional amps.
What worries me is this...(from a JVC RX-D401S)
"110 watts per channel, 6 ohms at 1kHz, with 0.8% THD"
#1/ at 1kHz ?!? That's just one freq, not a range. I'm used to seeing 20Hz-20kHz. Is this just a way of saying that it can't do 110 watts with any more than one freq at a time?
#2/ The other concern is this 6ohm thing. I thought the accepted standard outlined by the Federal Trade Commission said that home amps were to be spec'ed at 8ohms? Are we slipping backwards here? Are 6ohm home speakers making a comeback? Are there special digital speakers you must use for a digital amp that are 6ohm.
I'm a bit confused.
Thanks for any explanation.
Wayde
I'm a bit confused.
Wayde
