Troy TN
- Apr 2, 2000
I have the 5803 Denon and I have done the internal test tones with a Radio Shack slp meter. I also used Avia to set my DD and DTS surround modes. Using Avia I had to raise the rears about 1db compared to the Denon internal test tones. My question is how do I set the analog external inputs speaker levels for my Panasonic rp82 dvd audio player on ext 1 and Sony SACD player on ext 2?
Would you recommend I raise the rears 1 db for these since Avia had this for DD and DTS?
How do you set your dvd audio/SACD speaker level analog input speaker levels?
