I've got an old TV that i can only use SCART cable. Is that mean that OSD won't work on my TV? if so how shall i calibrate my sistem without OSD? is that possible? i appreciate any help. thanks...
I believe that one of the four buttons surrounding the Select knob (maybe the Ch. Level button) will show the levels of each of the channels. Turning the Select knob will adjust the level up or down and pressing the Ch. Level button will change the channel.
That's probably a good idea. I'm really not sure if you need an OSD, but by the time that you work all that out you'd probably have a scart convertor already. You don't need a high quality one just to see the OSD.
And it'll be so much easier to adjust next time something needs changing.
