darren_b
Grip
- Sep 13, 2002
Just bought me a Denon 1803....very happy.. Theres so many setting and so forth, which leads me to a few questions.
1. To get good loud sound i have to put the volume up to -27 db (ranges from - 70 to + 16 db)Is this normal? I'm using 6 Ohms Jamo X series speakers
2. Is it a good idea to adjust the sound level of each speaker, say to, + 5db, or leave it at default 0bd (what do most of u do)If i do this, it's abit louder.
3. Do speaker cables make a huge difference in loudness?
4. Do you guys turn the Tone Defeat ON or OFF when listening to dvd's? Sounds less bright when off, to me anyway, but the manual says if u turn it ON for a higher quality sound!!!
5. (LAST ONE!!!!)
Setting the Subwoofer mode, Is it better to have it on NORM or MAIN. My front and centre speakers can handle 20 hz - 20000khz)
Thanks heaps in advance to replies.
Frustrated but happy owner
5. (LAST ONE!!!!)
