Jerry Klawiter
- Dec 3, 2000
Both 24" monitors now have the status of Sale Pending One to Ken from this forum.
The other to a nice gentleman from Video/AudioGon.
I purchased a Dell 2405FPW 24" lcd just over a week ago.
I could not get my video card DVI out to do the full 1920x1200 native resolution. I had no problems with my video card outputting this resolution via RGB "VGA". So I was thinking the monitor dvi input was not working properly. So I had Dell send out a replacement, with the same results, duh, I look at the box of both my fx5500 & fx5600 video cards. The max resolution via DVI out on my video cards is 1600x1200, my video cards are lower end, many other video cards will support 1920x1200 via DVI.
1600x1200 also does look fantastic.
My invoice on this exchange replacement monitor said I need to return within ten days or detach and pay the amount due.
Well the price is an attractive price, so here it is, maybe someone needs a deal.
The monitor is a Dell refurbished 2405FPW, current Dell price for new is $1199.99 The current Dell refurbished price is $998 when available. At the asking price of $750 I really do not have much wiggle room for online payment fee's, I'm sure we can work something out. I am a longtime paypal member. Both my Audiogon and eBay member name is cyber16.
I have solid 100% positive feedback.
You will also find that I am a master trader here.
This is a killer monitor & includes everything that it is sold with, DVI cable, VGA cable, USB2 cable, Power cable, Dell CD that include electronic documentation and driver if needed.
There are no flaws, no stuck or dead pixels, looks brand new.
Here is one of many Review: Dell UltraSharp 2405FPW Widescreen LCD
http://www.extremetech.com/article2/...1764466,00.asp
Follow the link for further information.
DELL 2405FPW
and here
http://accessories.us.dell.com/sna/P...ctlisting.aspx
Product Highlights
Clear, sharp images at a maximum resolution of up to 1920x1200 pixels
Wide aspect panel improves productivity with less scrolling and toggling
Supports advanced features like PIP (Picture in Picture) and PBP (Picture By Picture)
4 USB 2.0 ports — two located on the side of the display for easy attachment/detachment of peripherals
9-in-1 Flash card reader on side of the display
Add multimedia capability to Dell™ UltraSharp™ 2405FPW display with the optional AS500 sound bar
Dell-branded monitors undergo exhaustive testing for performance, reliability, durability and compatibility with Dell™ systems
Supported by Dell™ Tech Support
Overview
The Dell™ UltraSharp™ 2405FPW 24-inch Flat Panel LCD Monitor is a wide aspect desktop display that redefines the performance of LCD displays with a stylish new design and advanced functionality. Watch DVDs in natural format and run multiple applications simultaneously. Improve productivity with less scrolling and toggling. The 2405FPW wide aspect LCD also provides 12 ms response time to enable crisp clear images when using the display for fast motion video such as gaming or video editing. With 4 USB 2.0 ports, 2 located on the side, the 2405FPW gives users convenient access points to plug in devices such as keyboards, digital cameras, secondary hard drives and printers. Integrated 9-in-1 flash card reader allows easy access to download photos or files. It also supports advanced features such as PIP (picture in picture) and PBP (picture by picture). With 3.93 inches (100 mm) of height adjustment virtually every user can adjust the display to their exact comfort level and help reduce eye and neck strain.
Diagonal Size: 24"
Display Type: Flat Panel Display / Active Matrix TFT - Desktop
Depth: 9"
Features: 100 mm VESA Mounting, Height Adjustable Stand Included, Detachable Panel mechanism
Height: Compressed: 22", Extended: 25"
Weight: 22.1 lbs
Width: 22"
Image Max H-View Angle: ±89°
Image Max V-View Angle: ±89°
Color Support: 16.7 Million
Connectivity Technology: Cable
Device Type: Flat Panel LCD Monitor with Height Adjustable Stand
Dimensions (WxDxH): 22" x 9" x 22" to 25"
Dimensions (WxDxH) / Weight: 22" x 9" x 22" to 25" / 22.1 lbs
Enclosure Color: Midnight Gray
Image Aspect Ratio: 16:10
Image Brightness: 500 cd/m²(typical)
Image Contrast Ratio: 1000:1 (typical)
Max Resolution: 1920x1200 (WUXGA)
Max Sync Rate (V x H): 76 Hz x 81 kHz
Power Consumption Operational: 80 W (maximum)
Diagonal Size / Viewable Size: 24" / 24"
Port(s) Total (Free) / Connector Type: 15-pin D-sub / DVI-D / S-video / Composite / Component / 4 x USB 2.0
Compatibility: PC
DELL 2405FPW
and here
Product Highlights
Overview
Diagonal Size: 24"
Depth: 9"
Weight: 22.1 lbs
Width: 22"
Compatibility: PC
