Mel Silva
- Oct 10, 2002
It has been a while since I have worked on my Shiva EPS sub, but I now have some time to work on it again.
I have searched through the archives and can't find a good answer to my issue. I want a nice and durable finish. I bought a piece of solid cherry 2x2 at the local Woodcraft for the sub legs(feet) and had enough to make some test blocks. I also bought Danish Oil (Cherry colored) and a Hock Shellac kit in Orange while I was there. Using my test blocks I have applied the Danish oil (3 coats) to one test block and the orange Shellac to another hoping to determine which finish I liked better so I could "get on with it".
I know that Shellac is both durable and non-toxic (sub plot: I will have a new-born in 6 months and need to consider if these things would be toxic). The Shellac is a beautiful, but very light, finish. I think I like the coloring and grain pop of the Danish oil better but I like the durability and hardness of the Shellac.
I can't seem to find anyone willing to "give away" information on how durable the Danish oil finish is, or how to protect it (who knows what may end up on top of the sub after it is finished and in the HT room). Can I (or more to the point, should I) put Shellac over Danish Oil? I have tried it on one face of my test block (put Shellac over the Danish oil) and can't see any difference in coloring or reflectivity. Should I put thinned Linseed oil over the Danish oil to protect it, or a wipe on poly?
What to do, what to do? Can anyone give me some sage advice before I pull my hair out? See the link below for the latest update to the sub-saga
Subwoofer Update
Subwoofer Update
