Bart H-worth
- May 5, 2004
This looks like the board to go to for good info, so I thought I would give it a shot. I have just bought a new house and am building my entertainment system right now. The house has a built in cabinet. I had originally thought about removing it and going with a RPTV, but I think I will just keep it and go with a direct view that will fit.
I have a good audio system and come from an "audio background". Not surround, but a high quality stereo/sub setup.
For the TV, I have about 39" width to work with. I will be using DirecTV and my Sony DVPNC685V for video. I may get a Bravo or Samsung upconverting DVD player later. I want the TV to have HD capability and would prefer DVI connections. The obvious choice is the Sony 34" XBR widescreen. Unfortunately, I just can't bring myself to pay that amount. I do like the widescreen format, as I am concerned with DVD performance and think the modified picture looks better on a 16:9 set than a 4:3 if you change the aspect ratio.
Sorry for such a long post, but here are some TVs and prices I can get - what do you recommend? Oh, anf the room is about 14' x 14' with a viewing distance of about 110". There are windows only on the wall that the TV is on, so none are on the front of it. There are woods outside those windows.
Thanks in advance for any advice or other info you might be able to help me with.
-Bart
- Sony KV-34HS510 - $1600
- Philips 34PW8320(?) - $1400
- Toshiba 34HFX83 - $1750
- Zenith and JVC also have 34" widescreens, but I don't know a good place to buy - any sugg?
- I might consider a 30" widescreen XBR for a similar price as the above, though I think it would be too small. I can also get Toshiba, Philips and Samung 30" WS for about $900
- Maybe I should just get a Samsung 32" HDTV for $799 and live with that a few years?
-Bart
