Kenneth+S
- Mar 12, 2004
Hi,
I visit here often but don't post much, if at all. I do have a question though. Within the last couple of weeks I noticed that the horizontal lines on my tv dip down on the left side, facing the television. I seems to only effect the top portion of the screen. It is real noticable when watching movies in a 2.35 aspect ratio. When looking at the tv the black bar along the top of the screen will be straight on the right side of the bar, but then just towards the left side of the bar it dips down so that the top black bar looks uneven.
I am very picking about geometry issues and never noticed this before, It seems like it just started. My question is, can this be fixed?
My tv is a crt rear projection ( Mitsubishi model#WS-55313 ). It is a 03/04 model. 16x9
I do know about the service menus and actually know how to access the ones for this model. I can get to some of the functions that adjust geometry, but they seem to only stretch or squeeze the picture or adjust the vertical lines. None seem to effect the horizontal ones. (Yes, I did write down the original settings so that I didn't totally screw up my tv ). Also, before this happened I never entered the service menus, so I know this didn't happen because of me.
Please give me some advice on how to correct this, if it can be corrected.
Ken
Ken
