xslntx
- May 20, 2011
- Bryan
I've got an older Kenwood amp, a KM-105. I'm using it as a subwoofer amplifier. It's rated for an 8 Ohm load only, but both subwoofer drivers are 4 ohms. I have each driver wired to it's own channel, as I can't afford the power loss of wiring them in series. I'm fairly sure if I push it the way it's running now, it won't last long, so I'm looking for an active cooling solution.
I've got a couple computer fans laying around, and I can wire them into the amplifier to be switched with the main power, I'm just not so sure as to how to go about installing them.
My plan was to completely cover the top air vents, save for one spot in the center, where I'll put the fan blowing upwards. It'll take in air from the side vents, blowing over the heatsinks on it's way to the fan. Any thoughts? I'll take some pictures to make it more clear in a few minutes.
Also, does anybody have any experience with the KM series amplifiers from Kenwood? Are they any good?
