It's the mid-grade series, I think it's called Pro or Professional. I did check the other day to make sure it wasn't a directional cable and it's not, as far as I can tell. I didn't even know cables could be directional until I bought an AR Subwoofer cable the other day and just happened to notice the arrows. That's what made me check the component video cable. Could it be that the DVD player is somehow damaging the cable? It just seems hard to believe that I would have the same problem twice with the same type of cable How often do cables fail really?
The point of "directional" cable for sub is diconnecting the ground on one end to prevent ground looping. By making "direction" arrows- you'll connect the right end to the sub (the altered end to prevent ground loop).
