Akshay Dwivedi
Grip
- Jan 10, 2015
I have the following multimedia player: http://www.naaptol.com/hd-media-players/intex-it-mhp-1080-mini-home-hd-media-player/p/12303085.html
I use it for playing movies and songs from my USB stick...
My TV is: http://www.cnet.com/products/sony-klv-s32a10/specs/
Its complete manual is available here: https://docs.sony.com/release/KLVS26A10_W_OM.pdf
Now I can connect the media player to my TV using component cables and it works fine. The media player also has a VGA port and I thought I'll try connecting it to my TV using the VGA cable.
The problem is, when I do so, although the display comes up, the TV shows the input resolution as 1024x768 and when I choose 16:9 ratio on the media player, two black bars come on the top and bottom of the screen even though the video file I'm playing has an AR of 16:9 (720x404).
Correct me if I'm mistaken but if the TV AR is 16:9 and the video file AR is 16:9, there shouldn't be any black bars right? Also, why does the TV show input resolution of 1024x768?
