arunVB
- Jun 16, 2005
I am setting up a 5.1 system and currently have the Def tech BP 7002 (powered bipolar tower that has 4 5.25" mid/bass drivers and 10" sub) as mains, Def Tech UIW 94 in ceiling for the rear surrounds and Martin Logan Depth subwoofer.
For the center channel, I am not able to decide between the Def Tech CLR 2500 (5.25" mid/bass driver & 8" sub) and CLR 3000 (6.5" mid/bass driver & 8" sub). I auditioned the CLR 2500 at the local retailer and I liked its full range sound. I could not find any retailer that has the CLR 3000 available for the demo, so I could not listen to it or do a side by side comparison with the CLR 2500.
I would like some opinion from the people who have probably owned the CLR 3000 or compared the CLR 3000 with the CLR 2500. Is it worth the additional $200. I read in one the customer reviews for CLR 2500 is more precise than the CLR 3000 due to its 8" sub rather than the larger, slower 10" sub of the CLR 3000. Can anybody tell what does the user mean by a slower 10" sub and how far it this statement true.
I would really appreciate if any one, who has compared the 2 speakers or has had the CLR 3000, give some opinions asto whether it is worth spending the additional $200 on the CLR 3000 and what kind of improvement will you see with the CLR 3000 compared to the CLR 2500..
Also please note that the BP7002 tower mains have 5.25" mid/bass drivers. Will a center with the same driver size (CLR 2500 in this case) be more compatible with the mains or is it OK to have the CLR 3000, which has bigger drivers.
Arun
Arun
