cd inputs - xlrs vs digital coax vs rcas (1 Viewer)
Kevin T
don't know if you want to count it as wisdom but here goes:
xlr: use first if available...if not available use:
digital cable: use if your pre-pro has better quality dac's than your cd player
rca cable: use if your pre-pro's dac's are not as good as the dac's in your cd player or if you have an outboard dac.
hope this makes sense.
kevin t
David Susilo
most XLR uses AES/EBU standard, not S/PDIF although at least 50% of the the XLR output can be toggled between S/PDIF and AES/EBU
andriesprice
