Jim Mcc
Has anyone used carpet or carpet tiles on any of the walls in your theater room? If so, can you share your results, and any advice you have? What type of adhesive you used, etc. Did you do the entire wall floor to ceiling, or just the upper or lower half? How did it affect the audio in the room? Any pics of your room would be GREAT. Thanks.
IF I do this, I'm leaning toward using carpet tiles for easier installation. I'm thinking of doing it mainly for the look, not for any acoustical problem or improvement.
