James Edward
- May 1, 2000
I have a 2002 Camry with 15" wheels. What is a good step up in the handling department as far as tires are concerned? I know the ride would be somewhat stiffer with a better handling tire- that's fine.
I just find the handling/ride to be too soft with the stock Bridgestone Potenza RE92's. I know there are usually tradeoffs for better handling- stiffer ride, more noise from the tires, etc., but I can live with that if I get appreciably better handling.
Please let me know some to look into. Thanks...
