Samuel.....Welcome to HTF. To answer that question depends a lot on you and your preferences.
What is your budget, type of display, what is the main use of your TV, etc. etc. etc.
When I was looking at RPTV I was leaning towards the JVC HD-ILA 1080p sets. I thought that the 1080p sets just had a better picture than the 720p sets but.......that was MY opinion. Have sense decided to go FP but that is another story.
Just remember that very few current TV's will accept true 1080p input.....I believe that thru my info gathering the HP set is one of those few there may be one or two others but the list I believe is short.
My recommendation is buy the best TV you can that your budget allows and do a lot of test driving to see what you like.
