Pete_Jr
- Oct 21, 2001
Well they start digging my hole for the basement a week from Monday so I still have some time for research and answers.
I am right now just looking to run some wire in my living room for my surround speakers so I don't have to run the wire across the floor or through the basement. I'm not even sure what you call them but I want the plate in the wall so I can just plug the wire from the speaker right to the outlet on the wall.
I was planning to just do the surround speakers but should I do the fronts also? You must have to have the outlet in the front also to plug the wire in from your receiver right? I don't want to get to crazy with this because in a year or more I am going to put a dedicated HT in the Basement(getting the superior walls).
What size wire for the surround and Front? I also have a HSU Sub but again not getting to crazy will probably just put in front to avoid any problems running the wire.
Really don't want to mount rear speakers on the wall either so will probably get some stands. Do you guys have those outlets down low or up high by your speakers?
Any help would be greatly appreciated.
By the way in a few years when I do the HT are there HT experts that will come to your house and design and pretty much build it for you? Any good ones in the Syracuse area?
Pete
Pete
