AndrewLevine
- Dec 11, 2005
After getting a lot of help from you guys in picking out my system (HK AVR235 + Athena F2.2s) I decided I wanted to try DIY for a sub. Most people said to use a PE Quatro 15" and PE 240 watt plate amp. It is for 90% music (classic rock) in a medium room. My questions are:
-for an extra $20, is the 300 watt Bash amp worth it? (it has more power and a dedicated LFE input vs having stereo inputs, not sure if that matters) and if it is worth it, would i have to build a little cover to protect the innards because there is no backing?
-because the Q15 is not shielded, how far must i keep it from other electronic devices?
-(last, and possibly stupidest question) If I line the inside of the sub box with tin foil (between the wallls and foam) would this cut down on the distance the sub may be placed from electronics?
Thanks for your help,
AL
AL
