Dean Sellers
- Sep 6, 2000
Help guys,
I'm running a Denon 3300 receiver to a Parts Express passive sub.
When I try to set the level on my sub, the spl "bounces" about 4db. It does it with the receiver's internal tones and with test discs.
I usually use a TOA commercial amp, and thought the problem was with an input signal voltage mis-match. I swapped the amp out with a receiver. Same problem.
Has anyone encountered this before? Is it my 3300?
Thanks Dean
Thanks Dean
