Kevin George
- Sep 10, 1999
i bought a 555 es player the other day from one call. it should arrive here tommorrow
i was wondering where you guys have been buying your sacd software as well as where reviews of the disk can be found. i ask because i know that some sacds definately sound better than others, problem being im not sure which are the better and which are the worse.
also, i know this will probably be covered in the manual, im a little excited though so im gonna ask anyways.....
is there a difference between using the left and right anolog outs on the 555 as oposed to using the left and right out of the 5.1 set.
thanks!
thanks!
