How about this one: http://www.partsexpress.com/pe/showd...=9387&CATID=43
156W at 4ohm for $80 bucks. You'd just have to change or find someone to change two resistors to change the boost from 5dB at 35hz to 1dB at 25hz and it should make a great cheap amp for an SVS.
Can someone explain about the bass boost on the PE amp. Why in the first place is it setup like that, I assume the negative to it is the hump in output you will see at the 35 Hz region. Is there any positive to it ?
I'm not exactly sure how you would disable the boost on this amp since the back is sealed. I'll have to double-check the one I have at home but it doesn't appear that the back is removable.
Thanks Jeff. Brian had my heart sank there for a moment. I'm trying to get a freind and my parents a 18-20hz tune 120L 12"DVC powered by one of those. I was counting on being able to disable the boost.
