I have a JVC XV-SA602SL DVD player with a Denon AV-1602 Reciever. My problem is when I run the composite video out of my DVD Player into the receiver and then out to my TV, the picture will jitter badly several times (probably 20 or more) during a movie. The audio works flawlessly. I have hooked up other DVD palyers to the same input on my receiver and it works fine. When I connect the DVD directly to the composite video port on my TV it works ok. I suspect I am not getting enough signal from the video out port on the DVD player. Any suggestions? Is there a problem with the DVD player? JVC "tech support" (and I use the term lightly) tells me there is no problem with the unit if it works O.K. connected directly to the TV. This is an inconvenient way to connect the components as I only have one input on my TV. Shouldn't I be able to connect the components this way with no problem? I have connected the composite output of the DVD player to the DVD video input, the VCR video input, and the DBS video input. All three do the exact same thing. The video jitters up and down at various times throughout the movie. When I hook another DVD player (Toshiba DVD/VCR combo)to the input it works O.K.:frowning:
