NickC
- Jan 19, 2000
Many of you have helped me select my current setup, but it isn't completed yet.
Current Speakers:
Mains: B&W 602 S3
Center: B&W 60LCR
Surrounds: ?????
Now, I can go multiple routes, but I am looking for opinions, suggestions, feedback, or whatever from poeple with similar setups or without.
My choices for Surrounds are
Another set of B&W 602 S3's(not sure if this would be overkill for surrounds, or if they would just be under used),
A set of B&W 601 s3 or 600 s3????
A listen to music, not multi channel yet, but I will upgrade at some point, whenever a mainstream format comes around, I play Video Games, and watch movies,I would say 50%Games/40%movies/10% Music right now, all this is in my bedroom, but will eventually be used in a theater type room, something else to keep in mind are the rear speakers, I would prefer the surrounds and rears to be the same in a 7.1 config.
Please share your thoughts
thanks
nick
Current Speakers:
Mains: B&W 602 S3
Center: B&W 60LCR
Surrounds: ?????
thanks
nick
