al lout
- May 6, 2004
Hi all,
It's being more than a year now since my DIY tempest sub. Now that I am itching to build the 2 front speakers. But first I have a few questions. I'm considering the A/V-3 from GR-Research. The pricing there is $329 for the kit and $64 for the sonicap upgrade. Other than that all I have to do is build the cabinets right? Do I need anything else like a solder or stuffs like that? I'm trying to budget myself to not go over $500 (including the shipping and finish in rosewood veneer). Is it possible for $500? The reason I'm considering the a/v-3 kit is becausing they do have a match center + surrounds that I will eventually build them. And also what will the a/v-3 compare to those comercial fronts (like paradigm studio 40 or 60, B&W 600 series)?
Any other kit should I consider for $500 just for the 2 fronts right now (need to help match center/surrounds for later projects)? I'll eventually build the center and surounds. If this helps, my room size is about 14x16x8. I mostly watch dvd movies. I would said about 70/30 ht/music.
Thanks for the help.
Al,
Al,
