Tim Christianson
Grip
- Sep 30, 1998
HELP! I just installed a Audigy 2 Platinum soundcard which has both SPDIF Coaxial and Digital Optical outputs. I have connected a coaxial cable from the 5 1/4 audigy drive on my PC to my Denon 5700 and can not get a signal when playing DVD's from my DVD drive.
Yes, I have selected SPDIF output in the settings and enabled the coaxial input on my receiver. Still no signal. I am using Windows XP with WINDVD 4. When the disc starts, the Dolby Digital Logo appears breifly in my monitor window, so I know that part is set correctly.
I do get a digital signal on my receiver when I select "digital output only" on the audigy 2 speaker settings though, just not 5.1. Only PCM. I can toggle it between 48 and 96 though.
Any ideas???
Tim
Any ideas???
Tim
