Brian Perry
- May 6, 1999
Long ago I purchased a Hewlett Packard 10x CD burner for my old Dell PC, and it worked great. The software was very easy to use.
I recently purchased a whole new Dell PC, and it came with CD burner built in as well as Roxio's Easy CD Creator software. It seems anything but easy.
Most of my burning involves making compilation CDs from various other original CDs. I then use the copies for my car. On the HP CD-writer, you would put in Original Disc 1, select tracks and then the burner would rip the tracks to my hard drive automatically. It would then ask for Original Disc 2, and the process would repeat. Once I had chosen all tracks, it would ask for a blank CD and then write the new CD.
Roxio's software seems to be much more difficult. Based on my reading of the instructions, it seems that I have to do one of two things: 1) Select tracks from Original Disc 1, then select tracks from OD2, OD3, etc. Once track selection is finished, I have to re-insert OD1, OD2, etc. for the ripping to begin. Or 2) If I choose to manually rip to hard drive, I have to name the tracks and then select them from a Windows menu. Either way, it's much more time-consuming than the old way.
Am I missing something here? Is there a way to make a compilation CD the same way I was doing before?
If not, can you recommend other CD-burner software that I could use? (I assume can't download or use the HP software from their website unless I am using an HP CD-burner. True?)
