Brian Mansure
- Mar 15, 2000
I have the oppurtunity to get a "free" shed from my next-door neighbor but moving it onto my property seems kinda difficult.
It's a complete outdoor storage shed approxmiately 7ft. wide, 6ft. deep and 10.5ft. high. Overall it's in good condition they just needed a bigger shed and were planning on tearing it down.
My brother, father and I looked at it and estimated that the whole structure probably weights roughly 900lbs. with most of that weight at the top with the shingled roof.
The size of the shed is not the only obstacle.
Although the shed is currently located only 40 yards from where it's going to be on my property, there is not enough clearance from a nearby utility pole and drop lines to move it straight across.
The only viable solution we've come up with so far is removing the shingles from the roof (most of the weight), then trying to seperate the roof from the rest of the shed and moving the walls, doors, roof seperately and reassemble on my property.
Have you done something like this before?
How did you accomplish it and what would you have done differently if given the chance?
I appreciate any and all suggestions.
Brian
Brian
