Mark Ward
Grip
- Nov 2, 2000
I've been searching for some discrete codes for my Panasonic TX32-PK20 TV to turn it ON and OFF separately rather than the On/Off Toggle.
I've found the equivelent codes for my Panasonic VCR so I'm fairly sure Panasonic will have included them on the TV also.
An email to Panasonic UK got the reply:-
Unfortunately the factory do not supply us with these codes as they are not
generally available to the public. They liase with the manufacturers of
universal remotes direct, so we never get the codes, sorry. You could try
searching the net or the manufacturer of your remote.
I've tried remotecentral and a couple of other sites without success and now wish to see if I can find it by trial & error. Does anyone have any tips on how to locate unknown codes using a Pronto?
Mark.
