I know this is probably a dumb question but I'm wondering if you have a lower watt system does it sound better if it gets turned way up? and with higher wattage can your system still sound good if the volume is a little lower? thanks.
I'm confused John, but is 3 db a big deal. If I get my speakers up to 60-80 db it's loud enough
When you are talking in terms of amplifier power then yes, 3db is a very big deal. It takes double the amplifier power to raise the volume 3db given the same resistance.
If a 50wpc amplifier can push a speaker to a certain SPL at 1 meter. It would take 100wpc amplifier to push a speaker that was rated 3db lower in sensitivity to the same SPL at 1 meter. For every 3db gain you wish, amplifier power must double.
Incidentally, the difference between 60-80db is HUGE.
