Rodrigo_T
- May 20, 2001
Hello...
Well, my 40H80 is I think finally burned-in! WooHoo...
I was wondering what DVD should I get AVIA? or Video Essentials? The cheaper the better.
So far I have:
--tweeked contrast, brightness,...with the FightClub DVD THX thingy
--Diasabled SVM
I plan to(in order)
--do electonic focus
--adjust geometry
--Overscan and image centering
--Herman TLV
Is the order right?
Also I have noticed these problems with my set:
If I look at a totally white image the white level varies from left to right...Like this...
I bet I can fix that with the geometry VARs right? Do I do it before convergace? When I try to converge the piont in the lower left corner it doesn't seen striaght also when you move either the R,B to the left it doesn't move in a straight line it starts to move down and rotate a bit.
Lastly I always see a BLUE HALO when doing the convergance...9 piont...
Thanks Guys! I'm sorry if the post is sloppy...
So far I have:
--Diasabled SVM
I plan to(in order)
--adjust geometry
--Herman TLV
Is the order right?
