Mike L-field
- Aug 2, 1998
This may be a dumb question - be kind if it is I was reading a review of a Mits. WS TV and it included a statement that the 4:3 image on such a set would be quite a bit smaller than it would be on a 55" 4:3 set. Is that true for all 16:9 sets?
I do know that the expand or Zoom features can fill the screen (with a somewhat distorted image). Anyway, if that is true for any WS set, which manufacturer(s) have the best "stretch " modes for using with 4:3 material?
While I'm here I might as well ask opinions too: I have narrowed my choice so far between the Tosh. 57 HX($2799), the Mits. 55" (probably the new platinum model w/ the integrated tuner and firewire) at @ $3200, or the Sony 67 KW 40 @ about $3000). Any other contenders?
Thanks in advance for your help.
