HELP (1 Viewer)
Qwadah
Karel
Hello
I have no idea if this is the right place to post this or not so I am very sorry if it is not!
The thing is I bought my parents a Hitachi home theater system, and it was working perfectly up until some months ago. No sound is coming from the speakers and I have been up and down the setups and tried everything, and google is not helping at all. I am very afraid that it might have something to do with the hardware.. since no setup is changing anything. It's a 5:1 and not one speaker is making a sound, but the movies play perfectly and there is a sound coming from the TV. My parents are rather old and therefor do not know a lot about technical stuff. I am not a professional either but I do know my way around basic things. All the wires on the speakers are in good shape but yet nothing works.
Best regards
Qwadah
Martino
Santa Clara, CA
Martin O.
From the sound of it, can be 1 of 2 things. There may be more (and I am sure you will get more options
1 - Fixable:
For the fixable one: System could be set to Mute - so no sound will go to the speakers. Having an HDMI connection will pass both the video and the sound to the TV - so the TV speakers will work, but not anything connected to the receiver. Finding the mute switch and pressing it will fix this issue.
2 - May be fixable - could have either blown a fuse or fried the amp. A blown fuse can be replaced, a fried amp in an all in one system usually means you need to get another one.
- Would also be helpful to include model numbers of anything - "Hitachi home theater system" assumes they make only 1...
papill6n
