Power Amp Fuse ? (1 Viewer)
Kendall T
Grip
Howdy, I have an old Pioneer GMH-100 (or GM-100?) power amp in my truck. It was supplied with a 10 or 12 gauge power wire and an inline 30 amp fuse.
My fuse housing has fallen apart and I want to replace it. I am curious if they use the inline glass fuses for a reason, or could I use a 30 amp blade type fuse instead?
Also, I am kind of partial to using fusible links in my high current demand, under hood circuits. Would a fusible link be acceptable for use on a power amp?
Thanks in advance...
Dean_S
It doesn't really matter what type of fuse you pick as long as it is the correct rating (30amp), fast blow and the fuse holder is appropriate for a 30 amp application.
Nielmb
