Please help w/newbie simple question. (1 Viewer)
clay_w
This is probably a really dumb question but, I just bought a "floor model" Onkyo HTIB and it did not come w/ any manual or wires. The connection for the powered sub appears to be the same as a digital coaxial cable, does the cable HAVE to be one specifically for power subs?
Thanks in advance for your help.
adamKI
Any decent coax cable with RCA type connectors should work for your sub. Just make sure the connectors fit snuggly.
Also, you can download the manual for your system from www.onkyousa.com. Just click on the downloads button at the top right of the page.
Similar Threads
Nielmb
