ridgerunner78
- Sep 5, 2010
- Ryan Goosley
Hi all - thanks in advance for any information you can give me. I do electrical work but have never ventured into the home theater scene until now.
I have a 12x36' room that will serve two main purposes - one side will be a home theater, the other will have a pool table and mini bar. It will be a basement room with engineered hardwood flooring on top of the slab. The drywaller is coming next week, so I'm trying to get all the pre-wiring done this week.
Question #1- I want to install a 5.1 surround sound system. I want in-ceiling rear speakers. (I don't have any components yet). Do I simply run two audio wires (+ and -) to each speaker location and run the other end of the wires to a junction box behind the wall where the amp will be?
Question #2- I want to have two in-ceiling speakers around the pool table. I've heard it's best not to have them directly over the table so sound will not echo. How far from the table should they be?
Question #3- I plan to run a 4-conductor wire from the amp to a volume control near the pool table, then two separate 2-conductor wires to each of the speakers. Is this correct or should both speakers be powered by a single 2-conductor wire (wired in parallel)?
