Kevin H
- Apr 22, 2000
Hello, right now I'm running a 1.2 ghz Athlon computer with 128 MB RAM and Windows ME. I have a copy of Windows XP and a copy of Partition Magic 7 and I'm wondering what is the best thing you think I should do.
The computer has a 60 GB hard drive, of which there are ~12 GBs left, but I can make more room. I don't know if I should create a partition with just the XP in it(and if so, what settings and what type of drive should I use, since i know nothing about partition magic) and keep the ME and all my data on the other one (of if that's even possible..) or just do a plain install of XP over ME, or what.
What do you think is the best thing for me to do?
