Updatable Player (1 Viewer)
Spottedfeather
Matt
I just got some blu-rays that won't play on any of the players in my house. The extras and everything BUT the movie will play, but when I hit play, the screen goes black and just plays the sound from the menu. I tried my dad's player, but the same thing happened, though this time, the screen showed the menu....though the screen froze and wouldn't do anything.
I tried on my PS3 and the movie WOULD play, but I don't want to use that because for some reason, the PS3 had a hard time sliding the disc back out. I don't want it to get stuck. I don't know if it's because the discs are not exactly official and are thicker because of the artwork, or what.
My question is....what are some good blu-ray players, 3D would be a plus, that will play these movies ? I thought I read somewhere that a player that can be updated over an internet connection might help in some way. So, something that has wifi would be a good idea.
Edwin-S
The player you already have may play the discs if you update the firmware. You should check the manufacturer website for the player that you have and see if a firmware update is available. If one is available, download it to a USB stick and use that to update your player's firmware.
Spottedfeather
Matt
None of our player are updateable....at least not anymore. My personal player is 10 years old. I was able to update it once by burning to a cd....but I don't have access to a burner anymore. The player in the living room is almost as old. The player that my dad has doesn't have usb, it's old, too.
I don't have the money for a usb stick, anyway. Thanks for trying to help, though.
aegisav
