Jeff Weight
- Nov 2, 2001
I own an Integra DTR 7.1 receiver with THX processing including EX. Should I use THX together with DD, DPL, & DTS? Will it add or detract from the sound if the original recording isn't THX? I have heard that THX is a post processing process that is done after DD, DPL, & DTS. If that is true what does it add that the original doesn't?
While I don't have THX certified speakers, I do have them set up in THX configuration.
Those who have THX, do you use it in addition to DD, DPL, and DTS?
