Edward J M
- Sep 22, 2002
Hi Jeff:
Thanks for the props, and it's no problem covering this question.
You nailed the furniture grade finish.
The PB2-Ultra also has the single band cut-only PEQ feature; very useful for taming a single peak in the response curve.
Finally, you've got the vaunted TV-12 driver. Yes, the dB-12 is nipping at its heels in terms of THD limited output; the TV-12 only has about a 1.5-2 dB advantage in that respect.
But the TV-12 has an underhung VC that maintains a consistent motor strength over the entire excursion range. The TV-12 VC also has ridiculously high thermal power handling limits (several thousand watts for 8-10 seconds). This means it can continue to convert electrical energy into useable output (instead of wasted heat) under extremely adverse operating conditions.
And yes, nearly all who have heard both woofers will tell you that the TV-12 subjectively sounds slightly better than the dB-12, even at lower volumes.
The dB-12 is a GREAT woofer for the price and offers the most bang for the buck in the SVS line-up. The TV-12 OTOH is the finest cost-no-object 12" woofer that TC-Sounds and Tom Vodhanel could design/build - PERIOD. A case of diminishing returns? Sure. But ask Tom, and he'll tell you the TV-12 is "worth every penny".
