glenn.arsenault
- Feb 5, 2003
I am looking for recommendations and opinions on subwoofers that are physically small (probably no more than 16" in height) that can go deep and are accurate. I do not need it to be loud (accurate frequency response is a preferred trait to max spl's). Predominant usage would be for HT with some music use. Probably will be in a system with Boston Acoustics or ACI speakers. Although $1000 would be a good starting budget, the budget could be increased if necessary.
Will be used in 585 sq ft room.
