I have just framed out my basement after completeing my Wifes dream home. Of course I planned the Basement out to be my "Man Cave" which of course has a dedicated HT. The room size is approx. 20'Wx23'Dx9'3"H with an attached A/V Room that I plan on building a custom Shelf Unit to have access to my Equipment and Storage. I plan on carpeting the floor and placing the Screen with 2 rows of 4 seats each (The second row on an 8-10" Riser with bass diffuser built in).
Question 1 - What recommendations do you have on wiring? I plan on a 7.2 Surround w/ 2 subs.
Question 2- I have a large entry that I plan using a "Sliding Glass door" to enter from the Bar/Poker Room. I figure with a 6' Glass Door, I will need to make a Curtain of some sort to cover the large area of glass to reduce the sound reflection's while enjoying the entertainment... Do you think this would be suffecient?
Question 3- I am planning on going with a front projecting unit. I can't find anywhere that gives a standard of putting the hdmi cable and of course electrical, which I plan to run through 3" conduit in the ceiling for additonal a/v cables. I can run to 2 areas if you think it would be a good idea, but I am just wondering if it is necessary. The first 1 would be at the rear (23' from the screen), and I was thinking of putting the other one approximately 10'-12'.
Question 4- What size screen would anyone recommend, and would it be fixed or not?
I am sure I will have more questions on equipment later... but thanks for any suggestion you may have.
Chris
Chris
