Todd Rozelle
- Jan 27, 2003
Hopefully I explain this correctly. I built a room that I installed in-wall speakers, these will be wired directly to my receiver to the "A" spkr selector. I also pulled speaker wire from my receiver to a gang-box in a wall then to a pair of outdoor speakers. My idea was to then install a Niles volume control in the box to control volume for outdoor speakers - these would be on the "B" spkr selector.
Now that I've actually started to think about it (after speakers and wires are installed), I typically will want the volume higher outdoors than indoors, so with both "A" and "B" depressed and Vol on receiver set to indoor listening level, I will be unable to turn up any higher than on the indoors. So should I install another volume controller on the indoor speakers and crank up the receiver volume using the 2 controls to attenuate? or is there a way to amplify the signal to outdoor speakers so I can set its volume higher?
