I have been trying to find speakers that will go with my Altec Lancing A7 Voice Of The Theaters. This has made it very difficult as they are very efficent and dynamic. I have been looking for the right speaker for over 6 years now and I could use some suggestions. So if you are familure with the VOTT's I would love to hear from you. Recently I was on JBL's web site and they have a new line of speakers. After looking into the JBL Project Array Speakers I thought I was all set and my seach was over. Well if I had loads of cash pouring out of my rear I would be ok, $15,700 not including a subwoofer for 7 speakers.
I currently use a Polk Audio CS100 center channel, its ok but is to small to keep up with the Altec's. The rear speakers are Advents that where always going to be temparary anyway. I use 1 pair for each rear channel, I use a Yamaha RX-V995 reciever which is also slated to be upgraded. I will most likely replace that with a Denon AVR-4306 7.1 reciever. And if everything works out I will add a power amp to it later. Would love to hear some suggestions.
Current Equipment List
Yamaha RX-V995 5.1 Surround Reciever - Will be upgraded
Sony DVP-S9000 ES DVD/SACD Player - Upgade or keeping ?
Denon DVD-2200 DVD/DVD-A/SACD Player
Marantz LV-520 Laserdisc
Denon DCD-1290 CD Player - Will most likely end up in a different room
Denon DTR-2000 DAT Recorder
JVC QL50 Turntable
Panasonic RV-9660 4 Head VHS - not sure why I still have this ???
Sony KDF-E50A10 50" HDTV
Equipment I will be adding:
Sony or Pioneer Elite Blu-ray HD Player OR HD-DVD player if Sony does not have there act together by next year.
Adcom GFA-7805 7 Channel Amp ?
1080p front projector
Stewert Film Screen - 120"
Looking into outboard Farudja 1080p video processor - depends on funds
JVC QL50 Turntable
