Shielded 8" subwoofer? (1 Viewer)
BenSC
So I've got a guy who likes my Dayton III's, but wants me to make him towers that use the bottom halfs as 8" subs. He has a small area to work with, so he'd like placement in close proximity to his TV.
Are there any options other than the AV8 from Adire in the sub $100 price range? A shame they don't make a shielded Dayton Quatro 8", as I really like that speaker, not to mention they're 30% cheaper. Not to mention its going to take 3.5 ft^3 to get the AV8 down to an F3 of 30htz.
Also, I'll be using the PE 120 watt plate amp to power the two 8's, then his amplifier will power the Dayton III's on the top half.
Thanks in advance.
DanWiggins
An AV8 in 1.5 cubic feet, tuned to 30 Hz does a really good job as a small subwoofer. Gets you into the 25-30 Hz range in-room quite well.
Dan Wiggins
Adire Audio
DarrenK
Grip
Hi Ben,
They're not quite ready yet, but I'm working on a new Dayton 8" shielded subwoofer driver. Xmax will be about 6 mm, and should do a vented F3 of just about 30 Hz in around 1.2-1.5 cu. ft. per driver. Cost will be pretty darn good.
But, unfortunately, it'll likely be a month and a half before they are in stock. I don't know what your timeline is like, but I just wanted to let you know in case you won't be doing this for a while.
See ya!
Darren
BenSC
This sounds very promising. I was planning to do these in a couple weeks for him, but perhaps I can push him off for a month. To keep in the +/- 3db range it took a 2.5 to 3.5 box for the other two woofers.
Out of curiousity, I'd like to give him the option of using the Quatro. He has the same TV as mine, and I can only get the sheilded 6.5" dayton within like a foot and a half without color issues. How far would he have to place the towers if the Quatro was in there? Probably around 3 or 4 right?
Thanks for all the helpful info guys, duno what I'd do without this place.
DanWiggins
Ben,
Must be something wrong with your software, then... To get an F3 (anechoic, without an XO) of 30 Hz, 2 cubic feet and a 30 Hz tune will do it.
BUT, don't forget the effect of the crossover! Include a low pass filter at 100 Hz, and the 1.5 cubic foot/30 Hz tune will get you down to 30 Hz without a problem. Without the XO, your F3 should be 40 Hz. But since subs rarely run without an XO, it should be considered in your design from the get-go.
And as Brian confirms, you can use a small vented box (even with a pair of AV8s) to play pretty darn low...:D
Dan Wiggins
Adire Audio
BenSC
OK, so I use WinISD, which is something I've used forever. But this is the second time I've been told that my numbers aren't right.
Here is my graph with a 3.5 cu ft enclosure and tuned to 30htz. I find it odd that my measurements are off because I've used this software numerous times and my speakers have tested pretty spot on.
Matt Dolejsi
just as a thought, dont limit your choice by whether a driver is shielded or not...large cancellation magnets and a little superglue can go a long way...just my 2 cents
David Giesbrecht
How about a Hi-Vi M8N its about $50 bucks at parts express and will play very low in a vented box.
Vas 1.88 cubic ft
Qts 0.45
Fs 29 hz
Xmax 5.8 mm
If you give each driver about 2.5 cubic ft to work with and a port tuning of 20 hz you would have an F6 of about 20 hz wich would easily be flat in room down to 20 hz.
Remember to consider room gain in the design! The anechoic F3 doesn't mean squat when you stick them in a closed space! The anechoic F3 of my Tempest subs are about 37hz and the in room F3 is 18hz and the F10 is at 8 hz!
The 8" driver Brian suggested would perform very similar to the M8N in the same box configuration as well.
BenSC
Very good points. Wow, that Hi-Vi is an.. intresting looking speaker to say the least. Does it glow? :)
I've got all these 8's on my list, and I've convinced him to hold off until the Dayton that Darren mentioned arrives. I'll make the decision based on that. Thanks again everyone.
BenSC
Well, I've convinced him to go farther away from the TV so he can use the Quatro as long as they don't have to be TOO far away. How far do you think I could get away with being? I'll place the sub's as low as possible in the towers.
I'm hoping for placement around 1.5-2 feet from the TV. which would put the quatro magnet at about 2 to 2.5 feet from the bottom corners of the TV, and about 3 to 3.5 feet from the upper corner (where color problems seem worst on that particular TV).
Dennis_H
DarrenK,
How is that new 8" Dayton coming? Any timeframe or specs yet? I'm looking for a small sub for a bedroom system and am considering this driver along with the AV8.
Dennis Hoenich
Nielmb
