Marc_Sulinski
- Jan 15, 2001
I am looking to upgrade my pair of Atlantic Technology PBM 350. These are 20+ years old, have a 12" driver, and a 200 watt built-in amp. I believe I paid $450 each. It looks like subwoofers have come a long way in the last 20 years, so I was looking to upgrade. I feel that these are only able to produce muddy bass rumbling, but cannot do punchy mid-bass and are not clean sounding at all.
I read through several threads on this, and am going to look into bass traps and the REW app (already ordered the mic). But given the room size and the relatively small size of the amps, I think I still need more.
My room is in the basement, and has variable ceiling height of 7-8 feet (there is a 1 foot soffit for half the room). The room itself is 24' wide by about 20' deep. There are other rooms in the basement as well. The most significant is a 12x12 room with a wide opening that sits off the back corner of the theater, with roughly an 8' opening.
That gives me about 4000 cu. ft. of space in the main listening area with an additional 1000 cu. ft. in the other room. The SVS rep I spoke to told me that the additional room should count even though it sits outside the main listening area.
I will be using these exclusively for TV and movie viewing.
The SVS rep recommended a pair of PB-3000, which puts me a bit outside my budget ($2600 for the pair), while my budget is about $2000. He said the PB-2000 would not be enough for the space.
I looked at some other options, and here are my top contenders:
SVS PB-3000 pair at $2600
HSU VTF-3 pair at $1550
HSU VTF-15 pair at $1750
Rythmik LV12F pair at $1200
Power Sound Audio V1512DF?
I see a lot of recommendations for the PSA TV1512, but a pair of those is over budget. How is the V1512DF? A little over budget but not too much.
The sweet spot seems to be the HSU, which is reportedly better than the PB-3000 and much cheaper for a pair. Even the VTF-15 comes in cheaper than the SVS. How much better is the VTF15 than the VTF3?It is quite a bit larger and getting close to the space limits I have.
Thanks for the help.
